intrigueing
- Joined
- Sep 28, 2003
- 11
Nice Forum, now time to help a newbie. Just got a 16 foot 1965 Clippercraft with a 85 Chrysler OB. I think the motor is a 1978 or 1979 (model 857HD Serial 1951)Any way to know year for sure? The lower unit has two small open holes on the right side of the motor - I am wondering what they are, and if they should have bolts. One is very small (1/8 inch diameter)-no threads just below the drain plug, seemed like a small amount of water was in it. The other one was lower and has threads in the hole, and had a small amount of gear oil coming out of it (again rather small - 1/8 inch diameter). Any idea what these holes are for and if they need to be plugged? The prop is in need of repair, and I need a spare. Is there any way to determine the pitch of the existing one? How do you pick the correct pich - trial and error, any recommendations? What gear weight gear oil should I use anyone use synthetics?? What repair manual should I get and where? Thanks for any input you can provide
