New to this section.
Bdt 1967
Last weekend I traded off my Glastron for a West Craft Super Sport. The boat is little known from what I have gathered using the google. But none the less it is known to me know. The boat has a 455 Oldsmobile and a Berkeley pump. I will be fixing up this boat so I am sure I will be needing advise. My first question is this the forum that I need to post in if I have questions regarding my pump or engine? Secondly how do I winterize this engine/pump. All i have ever had are outboards and I/O's this is a different setup for me. Any help would be appreciated.
Re: New to this section.
Ayuh,....
You're going to find that Jetboatin' isn't very common here at iboats,...
There are forums out there, that are Devoted to Jetboatin'....
I know Just enough about them to get into Trouble,...
I've got an old Berkley out in the wellhouse, tucked away for a future Project,...
It had a 455 Olds with it, but I gave it to a friend years ago....
Drain it,....
The Block,+ the Manifolds will/ should have Fittings,... Remove the ends of Hoses if you're not sure....
The Pumps don't hold water,+don't need draining....
