Re: new to trolling motors
Go to either the MinnKota or MotorGuide web sites. They have charts that can help determine what you need. I suspect you will need a 55# minimum which is at the top of the 12 volt motor range. Anything more than that is 24 Volt. If you are in salt water, you may be dealing with more wind and rough water so a bigger motor may be in order (65# or so). You will need two of the biggest deepcycle batteries that will fit in the space you have available for them. At the back of the boat that's a considerable amount of weight. If you are fishing a lot, you may consider a bow mount for better boat control and weight distribution. Bow mounts come with varying length of shafts. You would likely need a 54 to 60 inch shaft. Just my opionion!
