james082273
- Joined
- Nov 23, 2003
- 83
Every since the day I took it out of the box the motor has run awesome above idle, the idle in neutral has been fine but as soon as you put it in gear it seems like it is running on 1 or 2 cylinders. Every few seconds or so it will smooth up but then start missing again. At first I passed it on as the 25 to 1 break in mixture.<br /><br />But know I am off of the break in oil and have put new plugs in it. And still the same. Could this be a carb adjustment? Each carb has a screw adjustment that I assume is for the idle mixture. Can someone give me the starting adjustment on these?<br /><br />The butterflies seem to be in synch. It has fresh gas and as I mentioned it runs great above idle.<br /><br />Any ideals? Hopefully it is just something simple like the carb adjustment. Since I bought it online I hate to take it to a dealer
.<br /><br />Thanks,<br />James
