New Tow Vehical fresh outta the booth
gotboostedvr6
well i need it to tow my Boats
I wonder how the wife takes that excuse lol
It just came back from paint. What do you think?
I did all wet sanding, primer, bondo, and masking myself
the paint is 2 stage base/clear
Nova II 260
Re: New Tow Vehical fresh outta the booth
Does it match the boats color? Looks like a little orange peel in the last pic.
BLLDOGG
Orange peel looks good. Just as nice as a factory vehicle paint.
gotboostedvr6
well for $200 the (cost of materials) would you complain?
it was a favor with no labor charged i only payed for the dupont paint
bruceb58
So are you asking opinions on the paint job or how it tows?
For towing, the Toyota trucks of that vintage are fair at best. Clutch is the weak point.
rickdb1boat
Paint looks good. Hope it's a small boat you have to tow.....
kenmyfam
Would not be towing anything too large with that truck. What are you towing ??
gotboostedvr6
The largest ill tow with it would be a 18 foot bayliner not a heavy hull to say the least.
the truck is rated at 4,800 lbs GVWR the truck weighs in at 2,420 lbs
max 2,380 lbs GTWR
gotboostedvr6
Edit max GTWR is 2,080lbs they allow 2 x 150 lb persons
New pic to show the paints color a bit dirty but you get the idea
Terry Olson
The paint looks great. I'd hit the bumpers and wheels with the same blue to really make it pop.
bruceb58
I wouldn't tow an 18' Bayliner with that truck.
Botton line, those trucks were not made for towing.
gotboostedvr6
Ill keep that in mind but im still gonna do it.
bruceb58
Had the exact same truck. I used it to pull a 20' foot boat out of my side yard so that I could hook it up to my Suburban. Just from doing that it fried the clutch...and that was pretty level!
If you have an automatic, it might be a different story. What do you have?
gotboostedvr6
No offense but if you didnt ride it so bad or used 4 wheel low you would not have had that problem.
These trucks use the same exact clutch part number as a turbo Supra. The pressure plate is rated at 1850 psi which is good for approx 240 ft lb tq.
stock the motor puts out:
22RE 116 HP @ 4800 TORQUE 140 @ 2900
I wouldn't use this for towing long distances or over hills but around me it will work fine.
kywildcat
I tow my 18' Bayliner with a Toyota 4Runner with the v6 and 5000 lb. towing capacity. 183 HP, 217 ft lbs at 3600 rpm. It handles it ok, but I wouldn't want to attempt it with any smaller vehicle. I've owned trucks like in the picture, and they seem to be light in the rear and easy to push around with a load behind it. Its the stopping I'd be worried about, especially if you had to do it quickly in an emergency. But thats just my .02 worth.
gotboostedvr6
got to play in the snow lol
Threw out the original bench seat and fitted some nice buckets
sabastianunf
22re is a great motor. I think the clutch will be okay as long as it is a bowrider you are towing. I have an 19 foot cuddy cabin and I don't think that truck would tow it very well. Also watch your leaf springs in the back and make sure they don't bottom out. Even if they don't you will probably have to replace your shocks pretty reguarly to maintain a good ride.
gotboostedvr6
I went with a extra leaf (add-a-leaf) to give some life back to the springs and going to install rancho 9000 adjustable shocks to retain a smooth ride when towing
i am disappointed with highway travel, it really needs more power lol
