Re: New trailer questions
i'm not sure what all is available in wash down systems, as we are in fresh water. the only trailers i have seen using them, were in salt lake city ut. the best one i saw had, a female hose end to hook up a garden hose up to. this is connected to plastic tubing in the box areas of trailer with small holes drilled every foot or so to spray flood the frame with fresh water.
the marina trailers i have seen generally have two parallel, padded bunks that fit all. this and dry stacking with a fork lift seem to be the same principal. the only question i have and cant answer for you is how well they distribute the weight on the hull over a period of time. it looks to me like they would have point pressure and deform the hull. maybe not so much with a flatter fore to aft hull. some deep vee hulls seem like they fit this style better.
