Sea Rider
- Joined
- Sep 20, 2008
- 12,345
My 4 year old Rib trailer has had its final Waterloo Time when Rib sat on top after last outing, fell apart due to excesive erosion while living all year round on top of a wooden pier 12 ft above sea level.
Was custom built to Rib specs with1.5 mm metal frames cut and soldered together. Plan building a second exact same one but with thicker 3.0 mm frames to better withstand the tough inclemency of its marine surroundings.
The gross weight of the 450 Mt Rib, OB and new trailer combo should weight aroung 450-500 kilos, what's the Ideal tonge weight it should have when a scale is placed under it ? Will be adjusted by moving wheel axis back and forth till the ideal tongue weight is reached.
Leasson learned : Never build a trailer with thin frames...
Happy Boating
Happy Boating
