skunkedskippy
- Joined
- Apr 30, 2017
- 130
Had some rot issues so I chiseled out my transom, did some grinding, and now I’m getting ready to glass some wood back in. Never done anything like this before so I’m here to ask the experts some questions.
Sorry if the photos are bad. I had a weird half sun/half shade thing going so everything is zoomed in.
In in one of the pics you can see the bottom of the Mercruiser cutout and the outline of the repair of the original cutout (omc I believe). It’s clearly a bad repair so I plan to knock the patch out and reglass from the outside after replacing the plywood. seems straightforward but please let me know if there is better way to do it.
For the inside I thought I would start with a layer of csm against the skin with VE
2 layers of 3/4” acx ply either glued together with titebond III, or glassed with a layer of csm in between. Then glue the plys in with PB. I’ll probably use screws and fender washers from the outside to pull the wood into the glass. This is based on my lack of a clamping device. But if anyone knows of some affordable clamps, please let me know.
My first question is about making the cutout. Are there advantages/disadvantages to cutting it before or after gluing the wood to the hull? Only thing I can think of is that I would want to cut before gluing if I planned to clamp the wood in.
If you can look at my hand drawing without laughing, the solid outer line is the hull. Dashed line is the wood and the shading is PB. I’m not including the strakes in the wood outline just to make it easier - these areas would get filled in with PB. Drain plug hole is also not included to make sure water never has a chance of contacting the wood - this area would either be filled with PB or layers of glass. Probably do the same for the deck drain holes.
Then add layers of 1708 and build to thickness. Move on to the stringers, etc.
Appreciate any advice, comments, criticism.
