new transom cutout alpha one
ltfella
Hello I have a 1989 alpha one sterndrive i/o. I putting a new transom in and on top of the cutout there is two beveled slots on top for the steering. I cant find any info on how to cut that part out any advice be great.
GA_Boater
Some have used a hole saw, but that can be hard to control and is tricky with the angle and the taper.
Others have mounted the hardware and made the tiller clearance slot with a Dremel, small grinder, wood chisel, whatever tool they had to make the slot. With the hardware in place, you can flip the tiller from side to side until you have a full throw.
sogood
I used a small angle grinder, fitted with a flap disc. Cut out the bevel with the steering in situ. Just temporarily bolted up the outer transom assembly so I could be sure the steering yoke was operating fully, with sufficient clearance.
76SeaRay
Are you located in Washington State by any chance?
JASinIL2006
I used a holesaw, but that really only works if you cut that part first. If you’ve already made the rest of the cut out, there is nothing for the holesaw to grab into.
76SeaRay
Too far away, thought I could help as I just did mine but was able to use a Mercruiser cutout tool on mine..
