jcupo6
- Joined
- Jul 13, 2009
- 512
I have two questions regarding my 1990 Johnson 225hp outboard. My trim assembly needs to be replaced, and the shaft has a crack. The boat storage yard has a Johnson midsection and trim assembly for a 150hp, is there any chance this would work for me (I'm guessing no, but I hope so!)? I talked to the owner, who says he'll give a good deal if it'll work for me. Here is their ebay add.
http://cgi.ebay.com/ebaymotors/JOHN...2825081QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
If that works, ignore the next paragraph...
Here is a picture of my motor, you can kinda see the crack on the housing by the four bolts. The removable plate is cracked and the housing Right above the plate is cracked a little. I was told this doesn't need to be sealed but if I wanted to 3m 5200 would work fine. Does that sound correct? The lower unit has been pressure tested and is okay.
