New trouble with Fastwin
mfbear
I ran my 68 Evinrude in test barrel and was getting a lot of smoke and a gray oily crud in the water in barrel. What could be causing this?
JB
Re: New trouble with Fastwin
Smoke and gray, oily crud are what 2 stroke outboards make, mfbear.
When you run it in a tank it all stays there, concentrated in one place. When you run it on the lake it spreads out in a thin haze and film behind the boat and you don't notice it.
Bottom line, it is normal.
mfbear
Thanks JB. I just checked the lower unit oil and found I had water in it. I rebuilt the lower unit two years ago must have messed something up so I'll have to go through again.
wbeaton
Did you replace the seals when you rebuilt the lower unit?
