Re: new update on the 1960 40 hp johnson
Member # 6826 <br /><br /> posted September 17, 2005 10:12 AM <br />--------------------------------------------------------------------------------<br />Pinto.... I assume you're speaking of the domed cover that houses the compression release area of the 1960 and 1961 40hp Evinrude/Johnson.<br /><br />The only reason that dome would blow out is that the Compression Release Valve is not seated properly in the cylinder head.... that is, in the combustion chamber. A faulty or improperly adjusted valve would be leaking the full power of each and every combustion explosion up into that dome/cover.<br /><br />You'll need to remove the cylinder head, remove the valve, then (if possible) reseat that valve with valve seating compound which is available at any automotive parts type store.<br /><br />When the valve(s) are seated properly, you could even run the engine without those domes if you cared to.... but it would look sorta weird!<br /><br />The water? That's got to be a seperate problem involving the water jacket plate/gasket (the plate bolted to the head with many 7/16" hex head bolts).<br /><br />However, at any rate, with the cylinder head off, you can correct both problems.<br /><br />--------------------<br />ReevesJ32@aol.com<br /><br />30+ Years With OMC
