Re: New(used) engine check-up, newbie boater
I'm pretty sure it'll be a 2 stroke... I think all force's were. My standard practice on a "new to me" outboard is:<br /><br />1) get a service manual (unless it is one that I'm familiar with)<br /><br />2) replace impeller even if it pumps water OK (unless I'm SURE it's been done in the last year or two... like previous owner gives receipt that shows date). Usually when someone says it was done a "couple" years ago, its either never been done, or was done 10 years ago.<br /><br />3) do a compression test (normally I'd do this before I buy a motor)<br /><br />4) new spark plugs<br /><br />5) inspect wiring & fuel lines<br /><br />6) replace lower unit gear oil and seals/gaskets on drain & vent plugs (if gear oil is milky, you've got a water leak into it). Re-inspect it after your first few hours use. (pull drain plug for a second, you can leave the vent closed), it should look like new, not milky.<br /><br />7) inspect/replace drive pin ("shear pin") if so equipped (and buy a couple of spares to keep in the boat)<br /><br />8) inspect fuel line / primer bulb (handy to take a spare along if you have one)<br /><br />9) grease all the things that should be greased (including steering cable)<br /><br />When I go out with my "new" motor, I feel mucho better having a kicker motor on the boat in case of problems/catastrophe. I guess it depends how far from the launch/shore you're gonna be going. Definately stay close until you know it's running alright.<br /><br />you might wanna pre-mix the gas & oil (50:1) until you're sure the oil injection (if so equiped) is working. Mark the reservoir and see that it's using appropriate amounts of oil for the gas your burning... if it's correct, then stop pre-mixing. You might also wanna put the battery on a charger to make sure it's fully charged.<br /><br />If you're new to boating, having someone familiar with boats/OB's come along for the first outing or two would help you ALOT. For example starting a big 2 stroke can take a bit of a "knack". <br /><br />I personally never feel completely comfortable about a motor until it's given me quite a few hours of trouble free service. <br /><br />Good luck,<br /><br />Brent
