dingbat
- Joined
- Nov 20, 2001
- 16,883
I picked up the new heads gasket for my 97 200hp Ocean Pro. The gasket is shiny on one side and has some sort of a grey sealing "band" around the perimeter of the bolt holes on the ?block side?.
The head has been machined but the block sealing surface is much to be desired. I got the block back into fairly decent condition but I could use all the help I could get to make sure it seals.
Can I use sealer on the gasket and if so would Permatex Aviation do the job or is there a better ?less than perfect? sealing surface compound?
