New vinyl floor For 96 Fisher Pontoon with PLASTIC DECKING
Status
Not open for further replies.
rockfordpi
I am redoing a 96 24' Fisher Pontoon boat that has 1" plastic/ABS type decking. I want to go with something other than carpet. The problem I have is that the deck is held down by screws that have heads about the same diameter and thickness as a quarter (think about a nail with the head the size of a quarter). These are placed at the seams.
So, imagine a deck with quarters on it spaced about 2 x 4. I never noticed these showing through the carpet, but I am afraid they will telegraph through the vinyl. Any processes or product recommendations to deal with this?
I am looking at at least 80 mill vinyl, possibly marideck or infinity luxury woven vinyl, but I am open to anything that is durable and maintenance free in that price range. I am not sure about the EVA foam products.
Ideas or suggestions?
GA_Boater
Welcome aboard, Jim.
Are these screws raised and not countersunk?
rockfordpi
yes, raised, they look just like quarters laying on the deck, maybe 1/32 thicker, roughly same diameter
Groo
A belt sander can take a 32rd of steel off pretty quick. You may be able to just over tighten a hair as well
rockfordpi
I meant 1/32 higher than a quarter, not above the deck. I have tried heating the decking and driving them down a bit, but that tends to loosen the bolt and I am not sure if I can tighten the nut underneath without the bolt turning and their is no head on the bolt to hold.
Groo
Probably a square shank. Make sure it cools before cranking it it you used heat
CDAAL
Hi, I plan to replace the old carpet with new vinyl on our 2001 Fisher Ponoon Boat in a few months, I havent started yet but appreciate the info on the quarter size screws. I was wondering what type of adhesive are you planning to use on the plastic deck?
jbcurt00
Closed
rockfordpi joined, posted this topic back @ the end of May and hasnt been back since the end of May. Doubt he'll get or reply to your question, hence the 90day inactivity rule
CDAAL start a topic about re-skinning your 'toon's deck w vinyl.
Status
