Some of you may remember this 18hp I have been working on:
http://forums.iboats.com/showthread.php?t=296642
Its a 1966 Evinrude 18hp (tiller)
I replaced the impeller, and thermostat. and that all the work I did to the cooling system. It uses a bronze (?) housing, so no reason to change that, as there is no damage.
So, I started it up, expecting to see some spitting water out somewhere, but nothing came.
so I ran it for a minuet, then turned it off. I pulled the thermostat cover off, and everything was completely dry in there.
So, I know the impeller is in the right direction, and I know I lined the water tube up correctly. So, where do I start?
