new winch
scotty c
today i finally decided to change out my thoroughly rusted out 1500 lb manual winch.<br />the old one was basically welded to the trailer<br />so out comes the hacksaw....<br />about 2 hours later, i managed to saw through<br />all the fused metal and bolts. what a job!<br />the new 1800lb winch went on in about 10 mins.<br />only problem(maybe not) is the hook winds up<br />right onto the winch, a fairly snug fit.<br /><br />are you supposed to move the mast ?<br />all those bolts are rusted out as well !
Re: new winch
Ayuh,........<br /><br />It Sounds like you'll be needing to move the Winch Stand Forward,..........<br /><br />Do you have an Electric Grinder,..???<br />How about a Drill,..???..<br /><br />Either of those with the right Cutting Wheel,+ a Hammer,......<br />Should make Quick Work of the Rusted Bolts..........
tashasdaddy
Re: new winch
you may have to put a new winch stand on with a longer bow stop. the bow stop is suppose to be over (on top of) the bow hook.. this is SUPPOSE to stop the boat from moving forward in a quick stop.
