New wiring 1987 johnson 70vro
couth77
Hi guys, I'm not ready to do this just yet and haven't researched it yet, but wanted to get some early feedback from some of you guys who may have done this. If I wanted to replace the wiring harness from throttle to motor on my '87 70hp vro, where would I look? Are they even available? Thanks in advance..
What is your motor doing / not doing ?-----Or should I say it is just wires and you can make your own wiring and go to a terminal strip.----No need for the red rubber plug in if you use a terminal strip.
couth77
Hey man thanks for the reply.. The motor was actually running just fine w no problems to speak of the last time she ran (8 years ago) electronically, etc. But while stripping my boat down this last month and removing the throttle, I noticed some pretty serious corrosion inside a harness connector plug up by the throttle. Just made me think maybe the rest of the wiring may be questionable..? I DO know that my warning buzzer no longer works and needs replacing (ive seen those on eBay/amazon) but that's it. Maybe the harness is just fine. Also (forgive my lack of knowledge), what is a terminal strip? TIA
