new wiring loom
s1jor
have a volvo 4.3 (97) in a mariah 180, any idea's how much a total new wiring loom ais and how easy it would be to fit????????????<br /><br />thanks<br /><br />si
cuzner
Re: new wiring loom
Het s1jor... just a dumb question, what is a wiring loom? <br /><br /> Jim
Re: new wiring loom
Is this a Wire Loom for the Motor, or the Controls/ Gauges, or the Whole Boat...........<br />I'm guessing the Volvo built the motor/ control harness.....<br />And,<br />Mariah built the 1 for Everything Else...........<br /><br />Probably Cheaper,+ Easier to Build/ Repair what you have............
s1jor
Re: new wiring loom
i was thinkin for everything, the previous owner has obviously had some problems with controls guages etc etc and has patched different things up so not absolutely shore what goes where, just thought it would be easier to start again with a fresh loom for everything rather than follow what goes where, am i just being lazy???????????
ahein
Re: new wiring loom
I'm going to attempt the same project this winter on my boat. I'm removing all of the old wiring to the engine and controls, adding brand new guages, and upgrading to circuit breakers rather than fuses. With a similar situation to yours, the previous owner of my boat added and removed various components over time and scabbed in the wiring as needed, without much regard to correct colors or sizes. Tracing electrical problems is very difficult when you're chasing wires that change colors mid-ship.<br />I don't know about wiring standards in the U.K., but in the U.S. there is an organization called the American Boat & Yacht Council that sets standards for boat wiring (among many other things). The ABYC has determined wire type, colors, and sizes that should be used on many of the components commonly found in boats. They do this to ensure safety, and commonality among the many commercial boat builders in the U.S. It would be wise to follow their guidelines (or whatever organization sets the standards in the U.K.), and to pick up some books on boat wiring. There are a lot of differences between boat wiring and automobile wiring (which apparently the previous owner of my boat didn't understand).<br />Good luck. It can be done successfully if you are methodic and consistantly follow standards. Hopefully, the end result will be a new, reliable electrical system that will last for many more years.
s1jor
Re: new wiring loom
is it not possible to just buy a volvo made 1???????????????? instead of make 1 myself?????//
ahein
Re: new wiring loom
You would have to contact Volvo directly and give them all of the details about your boat/engine configuration. They may be able to supply part numbers for your engine controls wiring. Since your engine is fairly new, you may be able to find a dealer that has them in stock. It's certainly the best way to go about it, but it won't be cheap.<br />As Bondo said, you will probably have to contact Mariah to get the wiring harness for the boat components (ie, nav lights, bilge pump, horn, etc). They may or may not sell to the general public. Again, you may have to go through a dealer to get it.
