BananasCentral
- Joined
- Sep 21, 2016
- 39
Before this I'd only had trolling motors or a 5hp, always on flatbottoms.
I wanted something aluminum for taking to the Gulf spearfishing and did some CL boat shopping while on vacation last month.
No one around Central FL has ever seen one of these, pictured with a 2010 CRV that pulled it home. (I pull with a F150 around here)
<a href="http://photobucket.com/" target="_blank"><img src="http://i295.photobucket.com/albums/mm143/Gratewhitehuntr/20160903_1449061_zps611ed577.jpg" border="0" alt=" photo 20160903_1449061_zps611ed577.jpg"/></a>
We rode it around Lake Superior, this pic was taken after running round Mackinac Island, this is a lighthouse in St. Ignace.
<a href="http://photobucket.com/" target="_blank"><img src="http://i295.photobucket.com/albums/mm143/Gratewhitehuntr/SAM_9458_zpse077a648.jpg" border="0" alt=" photo SAM_9458_zpse077a648.jpg"/></a>
I got a good enough deal to do some work on it. MI vs FL boat prices are night and day!
Here is the easiest possible way to remove foam from a boat. 13hp 4000PSI pressure washer with turbo tip WATCH YOUR TOES!
<iframe width="560" height="315" src="https://www.youtube.com/embed/n1fZfjC7Quk" frameborder="0" allowfullscreen></iframe>
EDIT maybe the wrong section for restoration talk.
Where I could use some help is prop selection.
This is a 1976 Johnson 135hp
The trim pin is one hole from the bottom, bottom hole puts the bow down and sheds 2-3mph, 3rd hole goes lightly faster but is kinda rough and likes to lose grip.
I've moved load around and it hardly seems to matter.
Right now I'm running a SST of unknown pitch, max rpm 5200, max mph 36-37 as indicated by installed gauges.
Max mph is basically the same with one man or loaded close to capacity (1350lbs people)
Cruising I get 4000rpm = 20-22mph. 3000rpm =18-ish but feels like I'm lugging.
It does slip when turning.
It does have a hydrofoil.
It JUMPS to plane much faster than a bass boat we talked with yesterday.
I'd mostly like to cruise around 3000-4000 rpm or 20-ish mph and get better mileage, will frequently be loaded with XX fuel.
Dunno if I can hotlink or embed yet, it doesn't seem to be working, if nothing else it'd be nice to publish some pics of this grand ol tinny!
Thanks in advance!
DOH! edit
I was looking at Solas HR Titan #2453-130-17 Stainless Steel Boat Propellerhere at Iboats as possible replacement.
The SST prices are so low I won't bother getting it fixed, just keep as a spare/beater.
I've set $300 as the arbitrary limit for a prop, lots of props in that range and I'm not racing.
Thanks in advance!
DOH! edit
