Re: Newbe question
Is the steering wheel, key switch, and throttle missing??? And what accessories are you concerned about??? Motor controls are normally left on a boat when a motor is removed.
Only minimal mechanical skills are required to install a motor. Slightly more if you need to replace the motor controls.
If the controls are present, then you should attempt to locate a motor to match the controls.
