newbi control question
barrrj
Purchased a 93 fourwinns with a Johnson 115 outboard motor. THe boat has a side mount control system. Not sure exactly how it operates. I understand the trim tilt button, and of course push forward go forward ect. Under hte handle is a red lever, assuming it is to get out of neutral and go forward or reverse. When starting the engine,how do you give it more gas, without being "in gear". Probably a simple question, but need some guidence.
thanks
richie
mike343
Re: newbi control question
I don't know exactly where to point you but you need to find an owner's manual for the motor. I think this site has a Johnson/evinrude section. Start there.
QC
Let's try this in the OB non-repair section. Usually there is some kind of lever or button that disengages the shift from the throttle. Depends on the control itself, but I am sure you'll get more info here.
Good luck!
