newbie asks... about gas, venting and lock
jennis9
we have a 20' aluminum bowrider (merc 140 IO) that we dry store on the trailer at the marina. we just mounted our 9.9on the transom - it will be used as our trolling motor.
my husband had the same setup on his last boat and said he used to keep the 6gal gas tank stored on the boat and that most people with an outboard do the same. i am afraid that the fumes will collect under the canvas cover and we will be blown to canada! we have our massager also taking care of our two onboard batteries - again is this a risk? all equipment has been tested and I see other guys doing this. but i still haven't jumped off that cliff my mom always mentioned to as a kid...
also curious about how you lock the outboard to the boat? do you cover the motor to protect it?
I'd hate to have to remove most of the components to lug back and forth each time we go out - may as well store the boat at home... BUT i would hate to be unsafe and stupid. that is always a recipe for disaster.
tashasdaddy
Re: newbie asks... about gas, venting and lock
best way to secrue the motor is the thru bolt it. i have store my tanks in my boats for the last 40 years, enough air gets under there to vent it. just don't open it up with a smoke in your mouth.
jennis9
thanks TD - I have to tell my hub he was right. where do i find the thru bolt? I could not find one in a google search.
Ayuh,.......
In this case a Thru-Bolt is Any Bolt that goes Thru the motor mount,+ Thru the transom.......
It's not a Lock per'se,....
It just makes it Alot Tougher for somebody to just Steal the motor, because it's Bolted On.....
jennis9
yep - i am showing off my newbieness. i thought i was looking for a lock-type-bolt thing. now i know, and we are bolted through the transom. thanks again
