Newbie hard starting question
cobra1476
Just a quick question, got a 2002 saltwater series 150xl that has a hard time starting when motor is tilted up a bit. Seems like I need to lower it to a complete level for it to start.
Is this normal?
Also, How long do you have to push the key in for the choke?
I do squeeze the primer bulb until it feels hard...about 5 squeezes.
I can't figure out the easiest way to start this thing. On my old i/o boat all i did was to "pump/push" the throttle forward twice and bam it starts no problem.
hl
Re: Newbie hard starting question
I had the same problem and sometimes still do. Mine has a enricher instead of a choke. I push the throttle level about half way(in neutral) after pumping the ball. turn key to on position and push in for 2 seconds; engage starter. If you do hear the engine try to fire disengage starter and push the choke key in for 2 more seconds.Repeat until the motor starts. Be careful not to flood the motor because this is a headache. Good luck
cobra1476
Hey thanks HL!
Do you have your engine trimmed down at all?
Coloradolakeboy
I make sure the motor is level to slightly down when I start.
cobra1476
Hey thanks guys! I guess everything I mentioned is pretty normal with these motors.
