Re: newbie help
Welcome to iboats.
You should make an additional post in the evinrude/johnson outboard section
http://forums.iboats.com/forumdisplay.php?f=24 to address the motor.
Your boat portion will be a piece of cake to do but, (isn't there always a but?
) please take time to read through the restoration section. Read up on things like soaked flotation, stringers and transom issues.
The pretty painting portion is really the icing on the cake once you are all done. Our main concern is to do it right the first time. Sadly.......
there are some restorations that are going on that are in my book are totally wrong. We really want your boat to last and be safe for the duration.
Is the motor mounted? With the motor tilted all the way up place pressure on the prop and see if your transom flexes? Lift and push up and down for this.
You might even consider some test holes from the inside to hunt down rot in the boat....... test the flotation too.
Congratulations on the baby and we know that baby is going fishing
so, we want it ALL to be safe!
