Hi. <br />I've been reading these forums for a couple of weeks now trying to fix a friends motor he bought used an not running. He has a 1985 Johnson 150 20" shaft electric start, T&T. I have replaced the cables and fired it up on the hose and it ran great. Took it to the lake and it stumbles off idle while trying to plane. I have since learned that the carbs need cleaned out and I have them soaking right now.<br />The qestions I have are basic but I cannot seem to find them in the thosands of posts here.<br />1. What is the difference between a looper and a crossflow? Is it the style of manifold or what?<br />2. What range of V6 engines are similar to the 150 I'm working on? (example, 305,327, and 350 cid GM car motors are all similar with differences in bore, stroke, etc)<br />3. When driving the boat, should the motor be trimmed all the way down to get on plane then trimmed out to raise the bow or should a sweet spot be found and left there? <br />BTW, we are using a 14 1/2 x 19 3 blade aluminum prop on a 1986 Ranger bass boat.<br /><br />I have more questions to confirm what I have already done, but will wait to keep this short.<br />Thanks in advance.
