newbie here
dcjcdc
couple of questions
have a 1990 sunbird corsica with 5 litre cobra omc outdrive
where is waterpump located ...and is it easy to change
also noticed the trim gauge is not working and was told probably sending unit is not working
where is that located and finally
the blower squeals for 15 seconds than goes away..is that an easy job to replace with another blower
thanks
cr2k
Re: newbie here
Impeller is located inside the cover on the back of the drive. Easy to change.
Trim sender is a lever on (i think) starboard side of gimbal ring raise drive to see it is a lever attached to a spring loaded pot that rides on the front edge of the drive and sends the signal.
Follow hose to blower and see. It will either be 3 in or 4 in. Some are easy to get to, some you would swear they put in before they put the top on the boat.
Don't bother trying to oil it. never works. Blower is about $20-$30.
