jevery
- Joined
- Jun 16, 2006
- 538
My Merc 115 is obviously mounted too low on my new 17 aluminum fish and ski. Theres a lot of spray back there at speed. The AV plate is about 1-1/8 below the center of the keel (not the center line ridge, but right beside the ridge) when the plate is parallel to the bottom of the boat. The holes on the mount are 3/4 center to center. If I raise it one hole the AV plate will still be about 3/8 below the line from the hull and if I raise it two holes the plate will be about 3/8 above the line. Id like to get it right the first time. Would one notch (3/4), be enough or is that unlikely since 3/4 will still place the AV plate below the line from the hull. Top speed is fine even with the motor so low (45 mph). Id hate to go two notches and have cavitation issues. Any thoughts from you with experience would be appreciated.
