NEWBIE needs a little advice THANKS
bluebrownie
hanging the impeller on my 15 hp, lil guy outboard... i have the lower leg off, the shift rod has alot of apparantly carbon buildup on it... it's a 17 year old motor... is that normal...?
ALso, when i put the shift rod back in, do i "grease the WHOLE rod or just the ends?
What kind of grease? can i use high speed bearings grease like i used to pack my bearings on my trailer...?
Thx folksc
M
Maxz695
Guest
Re: NEWBIE needs a little advice THANKS
greese the impeller vains and the spline on the shaft. any greese is better than no greese thats what I use wheel baring greese
bluebrownie
is the carbon buildup normal on the shift rod?
M
Maxz695
Guest
not sure but that could be from leaking fuel mixture oil in the lower cowel dripping maybe like i said not sure though. exhaust leaking maybe
