Newbie needs to know what size engine to go with
dkontra
I just recieved for christmas a 17 ft 1963 aquaswan bay boat. It does not have an engine and i am wondering what would be good to go with. It requires an outboard motor and I do not know much yet and was hoping to get a response. I will not be looking to be a speed demon woith it, but dont want to crawl at a turtles pace either. Thanks<br /><br />Dave
Trevor
Re: Newbie needs to know what size engine to go with
what are the specs on your boat? weight, beam, transom height etc?
miloman
I agree with Trevor hard to tell you with out that but a stab in the dark you should be pretty safe with a 20hp look for a coast guard rating on the boat and it will tell you what the maximum hp is don't exceed it if it is your first boat I suggest 1/2 to 2/3 of the maximum hp
JB
I agree with Miloman, DKontra.<br /><br />I like to go with around 70% of the rated max HP for my Whalers. <br /><br />That has always allowed me to cruise at 25-28mph and get to 35 or more when I am in a hurry.<br /><br />I am going to guess that your Aquaswan is rated for 90 to 100HP. If that is the case I would be looking for a 60 to 70HP engine.<br /><br />Next will be your decisions about what an engine has to meet in the way of priorities and price.<br /><br />Let us know what you decide and what you will be looking for. :)
sloopy
I would go with a 75 fitch! great engine!
radsrh
What type of activity will you be doing with your new boat, depending on how much of a load you will have in it or if you might want to pull a tube ect. I would think about going more towards the max Hp. Just a thought, you might not use it all right away but it's cheaper then a re power if your not happy.
dkontra
My sheet stated 45 hpo is the max. the max weight of the boat(capacity) is 1200 lbs. wont 45 horses be slow? what could i in theory look at for speed? i dont want to use it, but its nice to know its there, if you know what I mean.
JB
Howdy, DKontra.<br /><br />When your boat was made outboard engines were rated at the flywheel. They are now rated at the prop, which means that they actually deliver 7 to 10% more power at the prop.<br /><br />If you boat is rated for 45, get a 40 and settle for what it can do.<br /><br />With correct prop and rigging, and assuming that your boat, fully loaded, weighs around 1500LB, You will get excellent performance.<br /><br />Potential WOT is about 32-33mph and cruise at around 25.<br /><br />For your boat I suggest one of the OMC looper twins or the preceding model 40.<br /><br />Good luck. :)
JB
Hi, Dave.<br /><br />Go to the top of the page and click on "Boat Motors". :)
