I'm new to boat motors and need help to get the old pontoon back on the water! The motor above starts good, purrs great, humms wide open, then after awhile it is like a couple cylinders cut out, like a switch turns them off. Seems electrical.
I was advised by one person the water pump was recently redone before I bought it and the small spitting of water out the back is normal that it never does have a solid stream. Another told me the pump wasn't working well and the engine maybe getting hot and the temperature sensor is reacting and cutting out the cylinders.
The motor doesn't seem excessively hot at anytime.
There is only a slight spitting of water out the 2 holes in the back above the water line.
I dropped the lower unit and took apart the water pump. Seems tight to me but there is a groove on the plate. I ordered an impeller rebuild kit from iboat.
1. What is the correct orientation of the impeller? I'm not sure what direction the 'cogs' were when it popped out.
2. Any hints on the installing the rebuild kit I should be wary about?
3. Any other ideas about this problem?
4. The starter isn't perfect, can I buy the starter drive someplace without the complete starter? If I need a complete starter, is this the cheapest place?
5. I also would like to find a tilt/trim for this motor. Other than ebay any suggestions.
Thank you very much in advance for helping me with this. Any help would be appreciated.
Bruce
Bruce
