utadventure
- Joined
- Jul 29, 2008
- 24
I had the boat out on Pineview Reservoir yesterday with the family. I've been trying to determine if I have on the right propeller but needed some information for the prop recommendation sites. Here's what I recorded:
Tachometer: 2600 rpm
Speed (GPS): 26.4 mph
Drive: Mercruiser 120 - 1.94 Ratio (my assumption)
Propeller: SOLAS 15.25D/15P
I put this info into the program and it tells me that I have a negative slip (and that it's impossible). If I assume a .15 slip and have it calculate the rpms instead using all the other know factors, it tells me my rpm's are 4250, which is in line with the expected 4000-4500 rpm range at WOT.
Based on this, would you suspect that the tach in the dash is inacurate?? by that much?
Dave
Dave
