Newbie questions
AznDrgn
I just bought a used lower unit for my 1961 75HP Evinrude and I have a few questions about it. First off it was setup to be an extended shaft so I got a short shaft to convert it, but while I was taking it apart yesterday I noticed a few things. <br /><br /> First off should there have been oil in the water pump? There wasn't a lot but there was some in there. When I saw the lower unit it was laying down and I have no idea how long it had been like that. <br /> <br /> The water pump impeller I pulled out of the waterpump is bigger than the one I bought for it but it still fits inside the housing and in order to line it up with the shaft the fins do have to bend a little and push up against the side walls, will this work?<br /> <br /> Once I have pulled the shaft I can see down into the gearcase, should i be able to see oil? Should I be able to turn it over and have some pour out? I was told that the lower unit had just had a fresh oil change and I can't see any oil down through that hole.<br /> <br /> Lastly does anyone know how to go about getting a replacement tittle? This boat belonged to a friend of my dads and he gave the boat to us a while back but he had lost the tittle so in order for me to register the boat I think I'm going to need to get a duplicate tittle.<br /><br />Thanks for all your help.
phatmanmike
Re: Newbie questions
you need a manual, and bad!!!!<br /><br />all of those questions couldve been answered easily by mr.seloc or clymer<br /><br />as for the water pump with oil, if it had ben laying on its side for some time, it could have been lower unit fluid draining out of a badly sealed unit. coulda been lots a things...
AznDrgn
unfortunately I can't find my manual right at the moment which is why I was asking.
red10
the impeller fins i believe are suppose to be bent to make a tight seal like a check valve so the water can pump upwards
D
DJ
Guest
1. New impeller fins are straight. They will form to the housing to make a tight seal. Make sure you have the direction right.<br /><br />2. Oil in the pump. It may be OK if the unit was on its side for a long time. However, I suspect the shift shaft and/or drive shaft seals need to be serviced.<br /><br />3. The oil is serviced by the drain and fill holes on the side of the lower unit. You will want to wait to fill it once it has been reistalled.<br /><br />Once reinstalled, run the engine in the water, and check the lube. If it is milky, the lower unit will need a reseal.
AznDrgn
Thanks for the replies. I Just have a few more things I want to confirm. This lower unit should use 80/90 marine gear lube and the motor should use NGK B8S plugs or equivalent, right? Anyone know where I can get a new timing belt? I haven't seen any listed at any of the online sites. I'm not 100% sure I'll need one right at this point but the motor has been sitting outside for about 7 years now and I'm afraid it might have gotten dry rotted.
D
DJ
Guest
The 80/90 is fine as long as it is marine.<br /><br />Use ONLY Champion plugs in John/Rudes. Many others here will second that opinion.<br /><br />Your John/Rude dealer can get the belt.
Joe Reeves
The timing belt list for about $46.00. Check with this site first. If it is not available here, I have a couple left in my remaining stock which I will discount one to $27.00. If interested, contact me at my address below.
