Newbie screwed up new boat. kids mad help me please
Joebklyn
I bought my 1st boat the other day. 2005 Bayliner Model 175BR (In X-Cellent condition) w 135hp Mercruiser engine & Alpha 1 outdrive or is that sterndrive. Kids thrilled, tubing etc. An hour into the day I hit a submerged rock. Boat ran fine no leaks. At the end of the day the trim button would not work(no noise from pump/motor) to lift the stern drive up into trailering position. Got the boat out of the water with 1/2" clearance. Went a few feet and the skeg started to hit the ground. (Damage was lightly bent prop). A fellow got a phillips screwdriver and played around with the 2 round trim control units on each side of the drive. The trim up button worked and the unit was raised. At home I pushed the trim down button and the unit lowered with motor/pump sound. When I pushed the trim up button, nada, no sound nothing. Now the skeg is on the ground and I can't even get it to the dealer to fix. Kids bummed out, wife is pissed I let the unit down. Any ideas? Any help is greatly appreciated. Thanks Joe
Haut Medoc
Re: Newbie screwed up new boat. kids mad help me please
Welcome to iboats......:)
Undo the two 9/16" bolts from the anchor pin, pull the trim cyliners off of the drive at the aft end & tie the drive & cylinders securely in the 'up' position to get ya to the mechanic......;)
Mike V
Stuff Happens;
Welcome to I-boats:D
Bt Doctur
what about the "Trailer button"?
180shabah
Ditto.
Were you using the trim up button or the trailer button?
Joebklyn
The boat did not come with a manual or anything. That is coming soon. From what I can see there is up and down rocker type switch that's all.
QC
The rocker (on handle, right?) should hit two stops, try the second one, push harder and see if that works. Prolly not, but worth a try.
180shabah
What is the make/model of your throttle control?
