bluemonster1
- Joined
- Apr 17, 2011
- 25
Hi all.This is my first thread on here and maybe I can get some info.I just bought a used 12 alum boat and 7.5 Merc outboard.This will be primarily used during the upcoming Flood situation we are facing in the next few weeks.Now the motor has been giving me static.First of all when I got everything home ..I wanted to try out the motor to see if it runs.Put motor in a barrel of water of course and proceded to start it.Now first of all the fitting from the tank hose to the motor was cracked(pissed off).I taped it up for the time being.knowing it will suck a little air probably.Got motor running, and it was not idling very good.I am still learning about these motors so bear with me.I found the fuel filter by removing the canister that sits over the top of the float bowl.It has some white crap in there,so cleaned it good and put back.It ran a little rough but ran.I since ordered a new complete fuel line with bulb and 2 new fittings now.I completely cleaned the carbs out twice already..today I made sure everything was clean.Mixed the gas 50:1 as required,choked it and it fired in like 5 pulls..runs good for a while,but after a bit I can't get it to idle smooth and sometimes it will just completely shut off.Once the motor has been running for like 5 minutes and then dies..it is really hard to start up again.Now if I put it in forward gear in order to open throttle more..it starts good,but I have to crank thottle down quick as the water in the barrel will fly everywhere..lol.Just can't get a consistant idle..sounds like it is sputtering and wants more fuel.,yet I can rev it up great and she sounds great.Overall there seems to be a slight up and down to the rpm's when running at 1/4 throttle.Anyways at idle for a bit and it will die.I adjusted the idle screw so the motor can keep a higher idle also,but sometimes still stalls out.Checked the fuel pump diaphram and it is good,the 2 valves inside move in and out,hoses aren't cracked anywhere or loose.SO...what the heck is going on here.I am so used to doing carb work on my 3 sleds that is doesn't bother me..but the carb is friggin clean now.What am I missing and need to try now.???The flood waters will be here soon and want to try and solve the issue.I mean I can still run her and just keep it above idle when I slow down or stop.HELP SOMEBODY PLEASE!!!!
Doug
thanks in advance.
PS: am thinking of finding another small motor just in case,but how do I know it won't do the same...
Doug
thanks in advance.
