newly rebuilt motor seized from sitting
twkjr 1250
just got motor out today 1977 4cylinder i/o merc pulled head off cylinders look pretty goood ,removed oil pan wa la brand new looking i mean shiny new but its seized loosened all ro bearing nuts and main bearing nuts got it to turn but it turns hard what the best thing to do now with it to get it to turn easyer is it possible the fly wheel is seized to the housing some how need some help with this one thanks for your support
natemoore
Re: newly rebuilt motor seized from sitting
What type of 4 cylinder? Also, punctuation makes it easier to understand the written word.
cr2k
Yeah, I about passed out trying to read that paragraph long sentence.
jerryjerry05
Take the drive off and see if it turns easier.Any kind of light oil in the cylinders might help.Battery good?Hook up 2 batteries and see if that helps.
This is a help forum not school.If you can't help don't add anything.J
natemoore
Yeah, but one does himself a disservice by making his post difficult to understand and tedious to read.
Alumarine
I believe he has the motor out already, so the drive is probably disconnected.
If he had punctuation and paragraphs, it would have made it easier to notice that.
6meter
With the plugs out, outdrive disconnected, you should be able to spin the motor by hand on the flywheel. Loosening the rod and mains says one could be tight. Tighten the mains one at a time and then spin. Same with the rod bearings. Check the clearances on the one that stiffens it up. Might even have swapped a rod or a main cap. Make sure there is oil on the bearings. Rings could also be rusted.
twkjr 1250
sorry about the gramma , most of it is my poor typing skills . with all the bearing nuts loose i will look into the rings being rusted. i didnt think of that with the cylinder walls looking rust free. thankyou guys for your input .
natemoore
i believe he has the motor out already, so the drive is probably disconnected.
lol! :D
