Nissan 1986 5hp NS5B Propeller Size
StarGazerI
I would like to change my prop size. :facepalm: Has anyone done this? Whats are the pros and cons.
Regards, StarGazerI
PS I gess now I have the basic MFG on now.
pvanv
Re: Nissan 1986 5hp NS5B Propeller Size
Robin,
There is a whole range of props for that motor. There is also a "mouse ear" high-thrust sailboat prop available, which may work on the Stargazer...
See the prop chart at http://www.tohatsu.com/accessories/prop.html
Any dealer (including myself) can supply a prop. But, knowing the correct prop for your setup is only speculation. You must do a little trial and error. You want to get as close as possible to the factory WOT RPM, without exceeding it. For a heavy dinghy, such as the Stargazer, the EE prop is a good choice. Good low-speed torque, but limited top end.
StarGazerI
Robin,
Sounds good to me Commander! So let me give you some background on my "heavy dinghy" and also a picture too. I had a special mast install that moves up and down to go under bridges and tight area's as seen in the photo's... Also the dinghy specs.
This is StarGazer I:
LOA --18'
LWL -- 15' 5"
BEAM -- 7' 5"
DRAFT, Board up -- 1' 6"
DRAFT, Board down -- 4' 3"
Displacement -- 1700 lbs. fully loaded including the wife's Cosmetics.. LOL
Ballast -- 400 lbs
Sail area -- 165 sq. ft.
Mast height above DWL -- 30'
Pictures: Mast up and down Mast up.jpgMast Down.jpg
Motor on back of StarGazer.jpg Nissan 5hp on back bracket that goes up and down
Lighthouse Dinner.jpgCapt. Rob.jpg Picture of me and Dinner at a lighthouse with wife....LOL
How do I tell what I have right now? Is there a marking somewhere? Is the EE the same as the "mouse ear" ? where do I see them or can you send me a link. Thanks again Capt. Rob of StarGazer I
pvanv
Rob,
Anything over 1500 pounds is considered "heavy". Your best prop will be the 3-blade high thrust ("mouse ear" or "elephant ear") prop. There should be cast-in markings on the current prop, either on the back of a blade, or on the hub between blades. Regardless, there is no other prop that comes close for sailboats. It's stock on the 6 hp sailpro model for just that reason. The last page (p4) of the 2-6 hp brochure http://www.tohatsu.com/tech_info/brochure_pdfs/2012_brochure/Toh2012_2-6.pdf has a small picture of that prop. If you'd like one, they are available from any dealer (including me). You would order 399B645121 PROP 4/5/6HP, 8.375" DIA X 6" PITCH (ELEPHANT EAR) $145.83. We sell a lot of them. In fact, should you one day want to retire the old M5B 2-smoke motor, the ultra-long (25") sailpro would be a great choice, as it comes stock with that prop, and also has charging capability.
