Nissan 40hp smoking @ startup
riverman0156
I have a Nissan 40hp 2 stroke year model 2003,as A guide on a local river I do a lot of starting and stopping,noticed that it is starting to smoke more,like when I run down the river(no excess smoke then)stop anchor out fish for a bit then on restart lots of smoke,only happens on restarts,and when in reverse(am running a jet on this motor)Do all my own maint. and service it often,it is oil injected.How can I solve this problem?Thanks in advance for any and all advice.Steve
TOHATSU GURU
Re: Nissan 40hp smoking @ startup
Could be the oil itself. Have the engine run it's self diagnostic troubleshooting program to see if anything else is wrong.
riverman0156
Have been using Quicksilver,How is the self diagnostic test run?The maint that I do is things like,plugs ,water pump,jet pump bearings and seals,replace the starter.Is there a special tool needed to run this test?Thanks,Steve
TOHATSU GURU
You are using an incorrect oil type and you need a factory service manual to read the codes out of the engine.
riverman0156
Have been using the merc quicksilver for several years,will be switching to one that is for the TLDI system,any suggestions?Also by using the quicksilver will I have put my motor in harms way?Thanks,Steve
TOHATSU GURU
The Quicksilver oil is not designed to be used in any DFI engine. Basically it causes an incomplete burn and will clog up the injectors over time. Any oil formulated for a DFI will work. Bombardier, Mercury, Yamaha, Tohatsu, Nissan, plus many generic brands, have an oil that will work. Your injectors are probably shot at this point and your engine has swallowed a lot more carbon than it was ever meant to, but I doubt that any mechanical damage has occurred.
riverman0156
Sorry gave you some wrong info,mine is the nissan plus,not the tldi,it has 3 carbs,does the info @ oil still apply?:facepalm:my mind ain't what it used to be!
Sea Rider
If it's 2 strokes TCW-3 oil for a carbed engine, go for it...
Happy Boating
riverman0156
yep its a 2 stroke,but still have the smoke issue on startup,as I explained on my 1st post.Thanks,Steve
Sea Rider
Probably oil inyection pump is having tech issues, you could disconnect, pre mix gas/oil 50:1 ratio to test directly. If doesn't smoke heavily on start ups, definitely a pump issue. Pumps are not eternal, do fail with long use.
Happy Boating
TOHATSU GURU
Completely different engine from the TLDI. No injectors and the Quicksilver oil is fine. So, you could have a weak part in the ignition system, some dolt could have touched the oil pump adjustment screw or any one of a hundred other things could be wrong. I would run it by a dealer and have them check the thing out. When was the last time the carbs were correctly cleaned?
riverman0156
Thanks for all the info,will be checking both filters,new plugs,decarb it with sea foam,then go from there.The oil adj screw is fine as I am the only one taking the cowling off,I.E. to add oil the oil tank.
