khoonie
- Joined
- Jun 22, 2005
- 67
I removed the lower unit on my 4 stroke 5 hp nissan and replaced the impeller, put it back together, but now it will not shift out of reverse (that is the gear I left it in for the repair). The shift rod that goes into the gearbox seemed frozen, so I took the LU off again. The drive shaft turns the prop forward and back ok. The shift rod will move up and down, maybe an inch, but it has no effect on the drive shaft/propeller movement. Help!!
