Re: Nissan 5HP NS5B Stuck Prop Thrust Bearing
If you are talking about the "Thrust Holder" which sits on the shaft ahead of the prop, you can use a 2- or 3-arm gear puller, but the arms will need to be fairly small. If it isn't super-corroded, you can pry it off, by using a large, flat screwdriver, and alternate the prying in different locations around the thrust holder. In really severe cases, you will be forced to cut (split) the old thrust holder off of the shaft, using a sharp chisel, or a "nut cracker" tool. If you do that, be careful not to damage the prop shaft. If you can pull the prop shaft housing out of the LU (not sure, depends on how much corrosion there is on yours), you can support the prop shaft housing on the jaws of a vise, and drive the prop shaft down and out of the housing, leaving the thrust holder behind. In the future, keep that area well-greased.
