nickbowman
- Joined
- Jun 16, 2011
- 2
I have a Nissan four stroke 6HP (6A2) that I use in a mix of salt and fresh water (located in Seattle). I've had the motor about 5 years and even though the water was circulating fine I figured that it was past due to replace the water pump impeller. I replaced the impeller based on some of the older posts on the site (thanks by the way) and everything seemed straightforward, but the water exiting the upper unit is now down to occasional drops instead of a steady stream.
Here are my 3 ideas so far:
- I scraped out some of the salt residue in the entrance of the water pump, perhaps a piece was dislodged and got stuck further up the near the water exit. I will check that with a wire when I am back at the boat.
- Maybe the impeller is not spinning. I don't think that this is likely, I spun the impeller with the shaft as I was re-attaching the top of the water pump .
- There is a leak in the path that the water travels through the water pump and out the motor. This is the option I am leaning toward. Everything seemed to re-attach fine, although I couldn't necessarily check how well the water pump exit seated to the tube leading to the upper unit, I could only see that they mated as I re-attached the lower unit.
I noticed that my lower unit is filling with water (and bubbles come out of the rubber grommet) when I lower my motor and run it. Is this normal? I guess it may be, but I never noticed it before.
Unfortunately none of my local dealers had a factory service manual, so I'm currently waiting as one is shipped to me. If anyone has any thoughts or tips on this, I'd really appreciate it!
Thanks,
Nick
Thanks,
Nick
