kyle williams
- Joined
- Mar 16, 2008
- 8
hello, I have a nissan NS9.9B2. it was running rough and when I took the cover off I could see the spark jumping from the wire cap past the plug to the block. Running on 1 cylendar. I figured it needed a new wire but on this model the wire is molded one piece with the ignition magento coil. I was told that nissan does not make this part anymore and I found a used one in a boneyard. it ran ok for a few weeks, now it is doing the same thing, on the same wire and plug as before (the lower of the 2 plugs). I found another used one in a boneyard and it is doing the same thing on the same wire. I know it is possible for used parts to all be bad, but it seems too coincidental that the same thing is happening with 3 different parts, (even used ones). Any suggestions for what else may be causing this?
thanks
Kyle
thanks
Kyle
