Nissan 9.9 shutting down - need help
hawgnutt
The motor starts on first pull and runs great for about 10 minutes then it bogs down and shuts off and the flywheel won't turn. If you wait a little while it will start back up and run for a few minutes or if you turn the flywheel (by hand) backwards and then forwards it will start and run for a few minutes then shut down. The water pump is pumping water and I've put a new head gasket on the motor. I've also bought a new fuel tank and fuel line. Any ideas of what my problem might be? The motor # is N99B2. It had been setting up for about 3 years before I got it. I'm guessing it to be less than 10 years old with very little use. It is a 2 stroke engine. Any help would be greatly appreciated.
rickdb1boat
Re: Nissan 9.9 shutting down - need help
Still sounds like it's overheating, even though the stream looks good. If it's been sitting for a period of time, I would rebuild Water Pump anyway, to be sure! Also check compression to see if the Motor is solid!
hawgnutt
Is there a site that I can find and download a service manual?
hawgnutt
Think you pinned it down Rick. The fins on the water pump impellar are chipped pretty much off. Thanks!!!
