Nissan NS 70B 1993 flywheel
jappo
Hi I am trying to find a flywheel for a 1993 Nissan NS 70B three cylinder? It would be a great help if someone could tell Me what the casting number is on this flywheel. The flywheel on My motor was taken and I am left with nothing to go by. The flywheel is no longer available from Nissan. Looks like a low hour fine motor dead before its time. Help Thanks jappo
pvanv
Re: Nissan NS 70B 1993 flywheel
Not sure about casting number (could be different) but part number is 3F3060911M. Fits the 60B and 70B. As you noted, it's NLA (no longer available) new.
jappo
Thanks pvanv for taking the time to reply, I don't think the casting no. and parts no. are the same.
You have a little different part no. than I have, Yours might be a updated no. The one I have is 3F306-0910M, My motor is a 1993 serial no. 3F3-1 20793 70B. I have a friend that is going to Asia in a couple weeks, He thinks it can be found there if we have the casting no. Thanks again for Your Help jappo
pvanv
Yes, your old number was superceded to the new one. The 70C is still being marketed new outside of North America, so you may get lucky, though the B model has not been in production for some time.
jappo
Thanks for Your help pvanv. Do You know if a 70C flywheel can be used on a 70B? I have found a used 70C flywheel off a motor that is being recycled for parts. Thanks again japjun
pvanv
No, I don't know for certain, but my gut says it won't work. The 70C had two different flywheels -- do you know whether the one you found is the new or old style? Regardless, the 70B flywheel part number is completely different from either of the C flywheels. You could call Tohatsu America at 214-420-6400 to see if anyone there is able to confirm whether it will interchange, but I doubt it.
