Nissan NS40C Disassembly - Hidden Bolt
Feathercraf1
I'm attempting to pull the power head off a Nissan NS40C
Does anyone have an idea how to remove the "hidden bolt" ?
Nissan Engine base bolt 910203-0640
Power Head to Drive shaft housing
pvanv
That attaches the engine base. After you have the power head off, you can pull that if needed.
Sea Rider
Asume that have disconnected the kill cord cables, disconnected the choke system prior removing the powerhead from its base. ? Have to wiggle the powerhead back and forth to lossen it from the base, probably still bit stuck ?
Happy Boating
Feathercraf1
Yes, all cables disconnected. Powerhead base shell is still fast connected to power head. Like I forgot two of the bolts. I didn't leave any bolts in. It's all still together. I didn't use a pry bar after I saw bolt 14. What exactly is press fit here? Is it a sealant on the parting surface?
Sea Rider
How many bolts have you removed so far from the lower motor pan ? that motor should have 6 lower bolts retaining the motor on top pan right ? Have you disconnected the throttle shaft rod that connects to the link rod that connects to the advancer arm ?
Happy Boating
