Nissan ns8b pee/indicator hole
Cbastuan
Hi guys,
I recently purchased a 1994-95 Nissan 8hp 2 stroke outboard.
It starts first pull and runs perfectly.
My question is that when it is running the water coming out of the indicator/pee hole is intermittent and not a steady stream like on my mercury 2 stroke.
Is this normal for this motor? I'm a assuming that it should be a steady stream.
If I inspect the impeller and it looks to be in good shape what would be the next step?
Thanks for any/all replies
pvanv
It should be steady. Probably could use a new wp kit (not just the impeller).
tommarvin
Ensign
1, Make sure the key is on the drive shaft, holding the impeller in place.
2.Make sure the fins are oriented the correct way.
3.If this is your first impeller change, You-tube explains it well.
4.What temp does the stat open in a pan of slowing heating water?
5.Some lower units you can take the water inlet cover off and look inside for blockages.
6. You need a factory service manual,i know where to get it for a fair price, check your private messages.
pvanv
It would not pump at all if the drive key wasn't installed.
Completely unimportant. They will flip to follow as the pump turns.
Unimportant unless the motor runs stone cold or is overheating. Opening the thermostat cover may be an issue if the bolts are corroded. In some cases, it's best to not disturb them.
Yes, the side strainers are removable on these, and that is always worth checking.
Tom, while it may have merit to check the stat if there is a temperature issue, it has absolutely no effect whatsoever on the pee tube flow
tommarvin
Ensign
Your right Paul, I will tone done my "I just bought this outboard" reply from now on.
Sea Rider
If the peeing port of that 8 HP is metal insert W40 red cannula fully in peeing port, spray an overdose of W-40, let penetrate/disolve small obstructions, poke up and down several times the cannula inside peeing port, can do this with OB on while throttling to higher rpm so water pressure helps clear small obstruction. On my 18 need to make this cleaning procedure from time to time or unwanted water intermittence will show up..
Happy Boating
