First post here, I have a 2003 Nissan 25 HP electric Start, tiller, long shaft 4 cycle motor with less then 40 hours on it, in the process of rebuild the carbs due to what else Ethanol. What can I expect to get for it on the used motor market ?
1 to 1.5 K...Ethanol does not normally cause a carb problem that can be solved by rebuilding. You probably have gummed up carbs due to fuel evaporation due to the carbs being left will fuel in them.
