Nitro Problems
lmeavtitn
I have a 2006 Nitro 640 lx and am having some troubles. I spent 3 hours trying to figure out what's wrong and spent quite a bit of time online trying to find a copy of the owners manual and a wiring schematic and can't find anything of the sorts.
When I went to start it today it didn't start. There was no clicking, the dash didn't light up and I can't tilt the motor. Everything else on the boat works like the bilge pump and live well pump. Also the trolling motor and finders works. The boat was in neutral and the safety swith on run.
I checked the fuses coming off the batteries and they look good too. Also none of the fuses on the panel are bad.
I'm wondering if there is another fuse or resister or something in line with the power that's preventing the boat from starting.
I'm at a loss and any help would be appreciated.
Re: Nitro Problems
Ayuh,.... Clean to Shiny metal Clean, the battery terminals, 'n the battery cables, at their Other ends,...
Corroded wirin' ends is the #1 cause of yer problem,...
