Re: NMEA CAPABLE GPS.. Any suggestions?
For some reason, C-Map is the preferred chart system (vs. Garmin's Bluechart) of the sailors I polled here in the PacNW. It might be because the higher end systems (Furuno, Si-Tex, etc) use C-Map, or suspicious type that I am, I suspect most people, in order to justify what item they spent money on, recommend the system they own. In any case, I just ordered a Navman chart GPS and, bought the chart chip direct from C-Map. I like the looks of both systems; I selected a C-Map compatible because it's not restricted to one brand as is the Bluechart.<br />In any case, something is usually better than no system at all.
