I have a Garmin Echomap 93SV and I want to add the Garmin steady cast heading sensor. I ordered the sensor but now I need to setup a basic NMEA network.
I've found various NMEA 2000 starter kits, most have Two T connectors, two backbone cables, one power cable and two termination plugs.
The steady cast heading sensor does come with a T connector.
I need to hook up both the Garmin chart plotter and the heading sensor. The steady cast heading sensor has a built in NMEA ready cable.
Can this setup be done without purchasing any additional cables or connectors? If not, what else do I all need?
Thanks!
Thanks!
